Author Topic: Mud-flaps
librarian
Mud-flaps
« on: March 06, 2008 »
Normally, slacken the 4x nuts on the stays, wiggle the mudguards out a bit then retighten.
Adjust the mudguard indeed!
JohnP's low-tech approach is a bit disappointing, frankly.
Get a smaller rear wheel, tube and tyre. You may need to change/replace the gearing (and possibly entire drivetrain). Consider whether deep drop brakes will be necessary, or (if fitted) having the canti bosses moved (professionally, of course - necessitating a respray).
There, sorted!
